Salta al contenuto principale
How to Fix Warped LEGO Baseplates
Cosa ti serve
  1. How to Fix Warped LEGO Baseplates, How to Fix Warped LEGO Baseplates: passo 1, immagine 1 di 1
    • Grab a pot large enough to place the LEGO baseplate in.
    • Fill the pot full of tap water, enough to submerge the baseplate completely.
  2. How to Fix Warped LEGO Baseplates: passo 2, immagine 1 di 3 How to Fix Warped LEGO Baseplates: passo 2, immagine 2 di 3 How to Fix Warped LEGO Baseplates: passo 2, immagine 3 di 3
    • Place the pot of water on a stove.
    • Turn the stove burner on to medium heat.
    • Heat the water to approximately 100 degrees Fahrenheit. Use a thermometer to ensure proper heat.
    • Do not heat water near or above a temperature of 140 degrees Fahrenheit to avoid damaging/melting the plastic.
  3. How to Fix Warped LEGO Baseplates: passo 3, immagine 1 di 3 How to Fix Warped LEGO Baseplates: passo 3, immagine 2 di 3 How to Fix Warped LEGO Baseplates: passo 3, immagine 3 di 3
    • Place the LEGO baseplate in the pot of heated water for 5-7 minutes.
    • Ensure that the LEGO baseplate is fully submerged for the entire heating duration.
  4. How to Fix Warped LEGO Baseplates: passo 4, immagine 1 di 1
    • Turn the stove off and remove the baseplate from the water.
    • Dry the LEGO baseplate using a paper towel.
  5. How to Fix Warped LEGO Baseplates: passo 5, immagine 1 di 1
    • Quickly sandwich the baseplate between two flat baking pans while the baseplate is still warm.
    • You can use any two flat, sturdy objects if baking pans are unavailable.
  6. How to Fix Warped LEGO Baseplates: passo 6, immagine 1 di 2 How to Fix Warped LEGO Baseplates: passo 6, immagine 2 di 2
    • Place two plastic clamps over the two pans to evenly apply firm pressure against the baseplate.
    • If clamps are unavailable, you can use weights to apply similar pressure.
    • Leave the LEGO baseplate in between the pressure of the baking pans for at least 5 hours.
Conclusione
If your LEGO baseplate is still warped after the 5 hours of sitting in between the clamps, repeat process and leave the LEGO baseplate in between clamps for an additional 5 hours.
Altre 3 persone hanno completato questa guida.
Nicole DeFer
Membro da: 09/26/22
224 Reputazione
1 Guida realizzata
CSU Fullerton, Team 1-5, Bruce Fall 2022 Membro di CSU Fullerton, Team 1-5, Bruce Fall 2022
CSUF-BRUCE-F22S1G5
2 Membri
3 Guide realizzate
1Commento della guida
100 degrees doesn't seem hot enough.
michael kithcart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 63
Tutti i Tempi: 3,717
