Salta al contenuto principale
How to Fix Thread Tension on a Juki DDL-8700
Cosa ti serve
  1. How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: passo 1, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: passo 1, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700, How to Fix Thread Tension on a Juki DDL-8700: passo 1, immagine 3 di 3
    • Thread the machine.
    • Insert the bobbin case.
  2. How to Fix Thread Tension on a Juki DDL-8700: passo 2, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 2, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 2, immagine 3 di 3
    • Sew a straight line on scrap fabric to test thread tension.
    • Be cautious when placing your fingers near the needle when working with the machine turned on.
  3. How to Fix Thread Tension on a Juki DDL-8700: passo 3, immagine 1 di 2 How to Fix Thread Tension on a Juki DDL-8700: passo 3, immagine 2 di 2
    • Check the fabric for loose thread tension.
    • Look out for loops of thread on the top and bottom of the fabric.
    • The bobbin case tension is too loose if loops are on the top of the fabric.
    • The upper thread tension is too loose if the loops are on the bottom of the fabric.
  4. How to Fix Thread Tension on a Juki DDL-8700: passo 4, immagine 1 di 2 How to Fix Thread Tension on a Juki DDL-8700: passo 4, immagine 2 di 2
    • Take out the bobbin case.
  5. How to Fix Thread Tension on a Juki DDL-8700: passo 5, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 5, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 5, immagine 3 di 3
    • Create a baseline thread tension for the bobbin case by tightening or loosening the screw on the bobbin case.
    • Thread should not easily unravel but can be pulled loosely.
  6. How to Fix Thread Tension on a Juki DDL-8700: passo 6, immagine 1 di 2 How to Fix Thread Tension on a Juki DDL-8700: passo 6, immagine 2 di 2
    • Reinsert the bobbin case into the machine.
  7. How to Fix Thread Tension on a Juki DDL-8700: passo 7, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 7, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 7, immagine 3 di 3
    • Sew another straight line on the scrap fabric next to the previous line.
  8. How to Fix Thread Tension on a Juki DDL-8700: passo 8, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 8, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 8, immagine 3 di 3
    • Check the front and back thread tension of the scrap fabric for loose stitches.
  9. How to Fix Thread Tension on a Juki DDL-8700: passo 9, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 9, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 9, immagine 3 di 3
    • Adjust the upper thread tension.
    • If there are loose stitches on the top of the fabric, loosen the upper thread tension by turning the tension knob counterclockwise.
    • If there are loose stitches on the bottom of the fabric, tighten the upper thread tension by turning the tension knob clockwise.
  10. How to Fix Thread Tension on a Juki DDL-8700: passo 10, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 10, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 10, immagine 3 di 3
    • Check the thread tension by sewing another straight line on the scrap fabric next to the previous line.
  11. How to Fix Thread Tension on a Juki DDL-8700: passo 11, immagine 1 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 11, immagine 2 di 3 How to Fix Thread Tension on a Juki DDL-8700: passo 11, immagine 3 di 3
    • The thread tension is correct if there are no loose stitches.
    • Repeat steps 5-8 as needed to achieve a consistent thread tension without loops on top or bottom of scrap fabric.
Linea Traguardo
UC Davis, Team 1-9, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 1-9, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S1G9
2 Membri
1 Guida realizzata
1Commento della guida
اَلسَلامُ عَلَيْكُم وَرَحْمَةُ اَللهِ وَبَرَكاتُهُ‎
yar khan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 82
Tutti i Tempi: 885
