Salta al contenuto principale
How to Fix The Hole For a Misaligned Door Latch
Cosa ti serve
  1. How to Fix The Hole For a Misaligned Door Latch, How to Fix The Hole For a Misaligned Door Latch: passo 1, immagine 1 di 3 How to Fix The Hole For a Misaligned Door Latch, How to Fix The Hole For a Misaligned Door Latch: passo 1, immagine 2 di 3 How to Fix The Hole For a Misaligned Door Latch, How to Fix The Hole For a Misaligned Door Latch: passo 1, immagine 3 di 3
    • Using your screwdriver, unscrew the top screw of the strike plate.
    • After unscrewing the first screw, remove the second screw as well.
    • Make sure to record the dimensions of the screw for the drill bit.
    • Remove the strike plate.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to Fix The Hole For a Misaligned Door Latch: passo 2, immagine 1 di 1
    • Locate where the door latch makes contact with the door frame.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to Fix The Hole For a Misaligned Door Latch: passo 3, immagine 1 di 1
    • Using your writing utensil, mark the spot on the door frame where the door latch makes contct.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to Fix The Hole For a Misaligned Door Latch: passo 4, immagine 1 di 3 How to Fix The Hole For a Misaligned Door Latch: passo 4, immagine 2 di 3 How to Fix The Hole For a Misaligned Door Latch: passo 4, immagine 3 di 3
    • Chisel out the wood, using the guideline you just created, that is keeping the latch from entering the hole.
    • Start at the top of the guideline, then work on the sides to create the new hole.
    Chiedi a FixBot
    Aggiungi Commento
  5. How to Fix The Hole For a Misaligned Door Latch: passo 5, immagine 1 di 1
    • Grab the strike plate and place it up against the new hole to ensure it is the right size.
    • If the hole is not the right size, repeat steps 2-4.
    Chiedi a FixBot
    Aggiungi Commento
  6. How to Fix The Hole For a Misaligned Door Latch: passo 6, immagine 1 di 2 How to Fix The Hole For a Misaligned Door Latch: passo 6, immagine 2 di 2
    • Mark the location for two new screw holes, using the strike plate as a guide.
    • Drill the top hole in, then drill the bottom hole.
    • Using the links provided in the introduction, ensure the drill bit you use is the right size for the screws you are using.
    Chiedi a FixBot
    Aggiungi Commento
  7. How to Fix The Hole For a Misaligned Door Latch: passo 7, immagine 1 di 3 How to Fix The Hole For a Misaligned Door Latch: passo 7, immagine 2 di 3 How to Fix The Hole For a Misaligned Door Latch: passo 7, immagine 3 di 3
    • Place the strike plate into the new hole.
    • Screw in the top screw, then screw the bottom screw.
    • Congratulations, your repair is now complete!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Now that the repair is complete, check that the door latch fits into the hole and that the door is able to close properly.
Altre 3 persone hanno completato questa guida.
Miles Huang
Membro da: 04/15/24
181 Reputazione
Una guida realizzata
UC Davis, Team 1-5, Morris Spring 2024 Membro di UC Davis, Team 1-5, Morris Spring 2024
UCD-MORRIS-S24S1G5
3 Membri
1 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 54
Tutti i Tempi: 1,188
