Salta al contenuto principale
How to Fix Subwoofer Amplifiers
Cosa ti serve
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: passo 1, immagine 1 di 1
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: passo 2, immagine 1 di 1
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: passo 3, immagine 1 di 1
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: passo 4, immagine 1 di 1
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: passo 5, immagine 1 di 1
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: passo 6, immagine 1 di 1
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
Linea Traguardo
Luke Turner
Membro da: 03/23/23
154 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 78
Tutti i Tempi: 764
