Salta al contenuto principale
How to Fix Scratches on a Steel Watch
Cosa ti serve
  1. How to Fix Scratches on a Steel Watch, How to Fix Scratches on a Steel Watch: passo 1, immagine 1 di 1
    • Fill any container up with water.
  2. How to Fix Scratches on a Steel Watch: passo 2, immagine 1 di 1
    • Grab any soft-bristled brush around for your convenience.
  3. How to Fix Scratches on a Steel Watch: passo 3, immagine 1 di 3 How to Fix Scratches on a Steel Watch: passo 3, immagine 2 di 3 How to Fix Scratches on a Steel Watch: passo 3, immagine 3 di 3
    • Dip the toothbrush in the water.
    • Brush along the crystal, bezel, and case in a circular motion.
    • Brush the bracelet in a linear motion back-and-forth.
    • Make sure to brush over the crevices of the bracelet for an optimal clean.
  4. How to Fix Scratches on a Steel Watch: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Dry the watch with a microfiber towel by pinching your fingers together in a back-and-forth motion.
  5. How to Fix Scratches on a Steel Watch: passo 5, immagine 1 di 1
    • Use the abrasive side of a sponge to brush the watch, following the same steps mentioned in Step 3.
    • Do not brush over the crystal with the sponge.
    • Apply minimal pressure to the sponge when brushing the watch.
  6. How to Fix Scratches on a Steel Watch: passo 6, immagine 1 di 1
    • Fold the metal polishing cloth in half.
    • Hold the corner of the cloth along your index finger.
  7. How to Fix Scratches on a Steel Watch: passo 7, immagine 1 di 1
    • Brush off all the scratches on the watch using a back-and-forth motion with great pressure to ensure effectiveness.
    • Perform the process as many times as needed.
    • Do not brush over the crystal.
Linea Traguardo
Youssefmo
Membro da: 08/31/22
195 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 547
