Salta al contenuto principale
How to Fix Loose Stitching on a Blanket
Cosa ti serve
  1. How to Fix Loose Stitching on a Blanket, How to Fix Loose Stitching on a Blanket: passo 1, immagine 1 di 1
    • Remove the loose threading using a pair of sewing scissors.
  2. How to Fix Loose Stitching on a Blanket: passo 2, immagine 1 di 1
    • Pin down the edges of the blanket one finger width apart using the safety pins.
  3. How to Fix Loose Stitching on a Blanket: passo 3, immagine 1 di 1
    • Choose the color of thread that best matches the original thread color.
  4. How to Fix Loose Stitching on a Blanket: passo 4, immagine 1 di 1
    • Push the thread through the eye of the needle.
  5. How to Fix Loose Stitching on a Blanket: passo 5, immagine 1 di 1
    • Begin sewing the blanket, making sure the stiches aren't too close together.
    • For this photo, a blanket stitch was used.
  6. How to Fix Loose Stitching on a Blanket: passo 6, immagine 1 di 2 How to Fix Loose Stitching on a Blanket: passo 6, immagine 2 di 2
    • When finished sewing, cut the remaining thread.
    • Tie the thread in a knot to close off the blanket.
  7. How to Fix Loose Stitching on a Blanket: passo 7, immagine 1 di 1
    • Remove all the extra thread remaining on the blanket.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 38
