Salta al contenuto principale
How to Fix Left Joy-Con Sync Issues
Taylor Dixon
Taylor Dixon e 2 altri collaboratori
Ultimo aggiornamento il 19 lug 2024
10 - 30 minuti
Moderato
Introduzione
Some of Nintendo’s first-batch left Joy-Con controllers are notorious for sync issues. This is due to a minor design flaw, and can be remedied with a small piece of conductive foam that can be often be found in old packaging around the house!
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Istruzioni Video
Conclusione
Altre 12 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Taylor Dixon
Membro da: 06/26/18
71.447 Reputazione
94 Guide realizzate
7Commenti sulla guida
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Replica
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon -
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Replica
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Replica
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 100
Ultimi 30 Giorni: 505
Tutti i Tempi: 44,454
