Salta al contenuto principale
How to Fix Joy-Con Drift Without Disassembly
Cosa ti serve
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: passo 1, immagine 1 di 2 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: passo 1, immagine 2 di 2
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
  2. How to Fix Joy-Con Drift Without Disassembly: passo 2, immagine 1 di 2 How to Fix Joy-Con Drift Without Disassembly: passo 2, immagine 2 di 2
    • Open the 404B contact cleaner and insert the tube into the nozzle.
  3. How to Fix Joy-Con Drift Without Disassembly: passo 3, immagine 1 di 1
    • Push the Joy Stick to the side and hold.
  4. How to Fix Joy-Con Drift Without Disassembly: passo 4, immagine 1 di 2 How to Fix Joy-Con Drift Without Disassembly: passo 4, immagine 2 di 2
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
  5. How to Fix Joy-Con Drift Without Disassembly: passo 5, immagine 1 di 2 How to Fix Joy-Con Drift Without Disassembly: passo 5, immagine 2 di 2
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
  6. How to Fix Joy-Con Drift Without Disassembly: passo 6, immagine 1 di 3 How to Fix Joy-Con Drift Without Disassembly: passo 6, immagine 2 di 3 How to Fix Joy-Con Drift Without Disassembly: passo 6, immagine 3 di 3
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
  7. How to Fix Joy-Con Drift Without Disassembly: passo 7, immagine 1 di 1
    • Wait 10 minutes for the liquid to dry completely.
  8. How to Fix Joy-Con Drift Without Disassembly: passo 8, immagine 1 di 3 How to Fix Joy-Con Drift Without Disassembly: passo 8, immagine 2 di 3 How to Fix Joy-Con Drift Without Disassembly: passo 8, immagine 3 di 3
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
Conclusione
Enjoy your Joy-Con being able to work properly again!
Altre 19 persone hanno completato questa guida.
Weijie Chen
Membro da: 01/16/22
706 Reputazione
1 Guida realizzata
2 Commenti
Muchas gracias.
AlmudenaPita - Replica
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 45
Ultimi 7 Giorni: 316
Ultimi 30 Giorni: 1,382
Tutti i Tempi: 36,439
