Salta al contenuto principale
How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012)
Cosa ti serve
  1. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012), How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 1, immagine 1 di 1
    • Before beginning, unplug the power cable, AV cables, and any controllers or memory cards.
    • Flip the console upright and check the label to confirm your model is SCPH-70012.
    • Never open the console while it's connected to power.
  2. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 2, immagine 1 di 2 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 2, immagine 2 di 2
    • Turn the console upside down so the ports face you.
    • Keep the console oriented the same way throughout the repair to avoid confusion when reassembling.
    • Use a small flathead screwdriver or spudger to carefully pry up the six square screw covers on the bottom panel.
    • Set the covers aside in order.
  3. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the six 4.0 mm screws from the bottom shell.
    • Keep screws grouped by location to make reassembly easier.
  4. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 4, immagine 1 di 1
    • Use an opening tool to gently separate the top cover from the base.
    • Start from the front edge near the controller ports and work the opening tool around the perimeter of the device to release the clips that hold the top and bottom together.
    • Work slowly, there are parts along the edge that can break if forced.
  5. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 5, immagine 1 di 2 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 5, immagine 2 di 2
    • Avoid touching the laser lens or any ribbon cables.
    • Dip a cotton swab in isopropyl alcohol and gently clean the right-hand guide rail and sled track.
    • Wipe away any old grease or dust buildup to allow the laser sled to move properly.
    • Avoid letting alcohol drip onto the laser lens or nearby circuit boards.
  6. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 6, immagine 1 di 1
    • Carefully rotate the worm gear at the top-right of the disc drive to move the laser sled to the middle of its travel range.
    • This position gives you better access for alignment and cleaning.
    • Don't force the gear - it should move smoothly.
  7. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 7, immagine 1 di 1
    • Use a fine tip marker to mark each of the four silver posts around the spindle motor. These posts, secured by 4.0 mm screws, control the disc drive's tilt and height.
    • Turn one post just a few degrees at a time to slightly change disc height or tilt.
    • Test the console after each small change until discs read consistently.
    • Over-adjusting can cause the disc to scrape or fail to spin. Work slowly and record each change.
    • Small adjustments (less than a full degree) can make a big difference in disc balance.
  8. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 8, immagine 1 di 3 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 8, immagine 2 di 3 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 8, immagine 3 di 3
    • Use a spudger to disconnect the ribbon cables from the board.
    • Refer to the guide, Recognizing and Disconnecting Cable Connectors, for details on how to disconnect a range of connectors
    • Avoid touching the board with your fingers or metal tools, as this can damage sensitive components.
  9. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 9, immagine 1 di 3 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 9, immagine 2 di 3 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 9, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the laser sled and guide rail in place.
    • Start with the right side screw, then move to the left as shown in the photos.
    • Keep each screw in order, they differ slightly in length.
  10. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 10, immagine 1 di 2 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 10, immagine 2 di 2
    • Lift the entire laser assembly carefully by its metal frame.
    • Hold the unit by the metal frame and avoid touching the lens or ribbon cable.
    • The laser should pivot slightly as it comes free from the guide rail.
    • The ribbon cable underneath is still connected - don't pull too high or twist the assembly.
  11. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 11, immagine 1 di 2 How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 11, immagine 2 di 2
    • Lift the laser assembly a few millimeters to see the two small laser potentiometers on the green circuit board.
    • The lift dial controls the CD laser, and the right dial controls the DVD laser.
    • To avoid damaging the board, don't touch it with your fingers or metal tools.
    • These components are delicate. Don't adjust them yet, just note their locations and orientation for the next step.
  12. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 12, immagine 1 di 1
    • Use a multimeter to measure the resistance across the outer and middle terminals of the DVD potentiometer.
    • Record the original reading (in kΩ or Ω) before making any changes.
    • This baseline ensures you can return to the factory settings if needed.
    • Be sure the console is unplugged and the multimeter is set to the correct resistance range.
  13. How to Fix Disc Read Errors on a PlayStation 2 Slim (SCPH-70012): passo 13, immagine 1 di 1
    • Use a precision flathead screwdriver to turn the DVD potentiometer clockwise by no more than 1-2 degrees.
    • This reduces resistance and slightly increases laser power for improved disc reading.
    • Over adjusting can shorten the laser's lifespan or burn it out. Make small changes and test after each adjustment before continuing.
    • The left pot adjusts the CD laser; the right one adjusts the DVD laser.
    • After reassembly, plug in the console and test it using several discs (PS2, PS1, and DVD). You should notice smoother spin up and disc recognition on the Browser screen.
    • If the console still struggles to read discs, double-check the ribbon connection and alignment posts before making further adjustments to the potentiometer. Avoid additional turns unless absolutely necessary.
Conclusione
Isabelle Applebee
Membro da: 09/22/25
217 Reputazione
1 Guida realizzata
CSU Sacramento, Team 1-12, Laflen Fall 2025 Membro di CSU Sacramento, Team 1-12, Laflen Fall 2025
CSUSAC-LAFLEN-F25S1G12
1 Membro
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 130
Ultimi 30 Giorni: 495
Tutti i Tempi: 2,377
