Introduzione
This guide is intended to show users how to repair broken glassware using non-toxic, food-safe resin to maintain its food-safe functionality. The object used in this guide is a glass tea infuser, but this tutorial is versatile and can be used with other glassware.
It's important to work in a well-ventilated area to avoid breathing the resin fumes. It is essential to use resin marked as food-grade. Use caution when handling materials such as resin, glass shards, craft blades, and hot water.
Cosa ti serve
Lay a garbage bag out on your workstation and put on disposable gloves.
Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
1Commento della guida
After applying resin, can I heat the item in open flame source ?
