Salta al contenuto principale
How to Fix Broken Powder Make-up
Cosa ti serve
  1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: passo 1, immagine 1 di 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: passo 1, immagine 2 di 3 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: passo 1, immagine 3 di 3
    • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
  2. How to Fix Broken Powder Make-up: passo 2, immagine 1 di 3 How to Fix Broken Powder Make-up: passo 2, immagine 2 di 3 How to Fix Broken Powder Make-up: passo 2, immagine 3 di 3
    • Pour a small amount of rubbing alcohol into the cap.
    • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
    • Do not use more than two caps worth of rubbing alcohol.
  3. How to Fix Broken Powder Make-up: passo 3, immagine 1 di 2 How to Fix Broken Powder Make-up: passo 3, immagine 2 di 2
    • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
  4. How to Fix Broken Powder Make-up: passo 4, immagine 1 di 1
    • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
  5. How to Fix Broken Powder Make-up: passo 5, immagine 1 di 1
    • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • If the powder is not fully dry, let it sit for another hour and continue to check back.
Conclusione
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
Altre 2 persone hanno completato questa guida.
Meghan Smith
Membro da: 04/09/15
224 Reputazione
1 Guida realizzata
Cal Poly, Team 30-3, Green Spring 2015 Membro di Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Membri
10 Guide realizzate
Un commento
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,715
