Salta al contenuto principale
How to Fix Bent Eyeglasses
Cosa ti serve
    1. How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: passo 1, immagine 1 di 2 How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: passo 1, immagine 2 di 2
      • Hold the temple and the end-piece of the eyeglasses together so that the screw-holes are aligned.
      • On a flat surface, carefully place the 1.4 mm slotted screw in the screw-hole.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Fix Bent Eyeglasses: passo 2, immagine 1 di 1
      • Use an eyeglasses screwdriver to screw the two pieces back together.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Fix Bent Eyeglasses: passo 3, immagine 1 di 2 How to Fix Bent Eyeglasses: passo 3, immagine 2 di 2
      • On medium heat, blow a hairdryer onto the bent part of the glasses in order to make it more malleable.
      • Using too much heat or heating the glasses for too long can cause permanent damage to the lenses or frames.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Fix Bent Eyeglasses: passo 4, immagine 1 di 2 How to Fix Bent Eyeglasses: passo 4, immagine 2 di 2
      • Gently bend the heated up piece until it appears straight again.
      • Bend the glasses lightly as not to snap or disfigure them further.
      Chiedi a FixBot
      Aggiungi Commento
    5. How to Fix Bent Eyeglasses: passo 5, immagine 1 di 1
      • Place the glasses on a flat surface. All four bottom points should be touching the ground.
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 38
Ultimi 30 giorni: 142
Tutti i Tempi: 1,549
