Salta al contenuto principale
How to Fix A Stripped Screw Hole
Cosa ti serve
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: passo 1, immagine 1 di 1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: passo 2, immagine 1 di 2 How to Fix A Stripped Screw Hole: passo 2, immagine 2 di 2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: passo 3, immagine 1 di 2 How to Fix A Stripped Screw Hole: passo 3, immagine 2 di 2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: passo 4, immagine 1 di 1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: passo 5, immagine 1 di 1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: passo 6, immagine 1 di 2 How to Fix A Stripped Screw Hole: passo 6, immagine 2 di 2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Conclusione
Your screw should now hold secure.
Isaiah Valdez Mireles
Membro da: 08/22/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 68
Tutti i Tempi: 1,468
