Salta al contenuto principale
How to Fix A Broken Makeup Compact Without Alcohol
Cosa ti serve
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: passo 1, immagine 1 di 1
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: passo 2, immagine 1 di 1
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: passo 3, immagine 1 di 1
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: passo 4, immagine 1 di 2 How to Fix A Broken Makeup Compact Without Alcohol: passo 4, immagine 2 di 2
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: passo 5, immagine 1 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, immagine 2 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, immagine 3 di 3
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: passo 6, immagine 1 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, immagine 2 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, immagine 3 di 3
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: passo 7, immagine 1 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, immagine 2 di 3 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, immagine 3 di 3
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Linea Traguardo
Cura Mclemore
Membro da: 03/21/23
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 188
