Salta al contenuto principale
How to Fill a Gap with Latex Caulk
Cosa ti serve
  1. How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: passo 1, immagine 1 di 3 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: passo 1, immagine 2 di 3 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: passo 1, immagine 3 di 3
    • Clean all surfaces and remove any clutter.
  2. How to Fill a Gap with Latex Caulk: passo 2, immagine 1 di 3 How to Fill a Gap with Latex Caulk: passo 2, immagine 2 di 3 How to Fill a Gap with Latex Caulk: passo 2, immagine 3 di 3
    • Use the latex paint remover spray for the areas that have remaining material along with the gaps. These areas also need to be replaced with new material.
  3. How to Fill a Gap with Latex Caulk: passo 3, immagine 1 di 3 How to Fill a Gap with Latex Caulk: passo 3, immagine 2 di 3 How to Fill a Gap with Latex Caulk: passo 3, immagine 3 di 3
    • Use scissors to cut the head of the caulk tube at a 45 degree angle.
    • This will help to better fill the gaps.
  4. How to Fill a Gap with Latex Caulk: passo 4, immagine 1 di 3 How to Fill a Gap with Latex Caulk: passo 4, immagine 2 di 3 How to Fill a Gap with Latex Caulk: passo 4, immagine 3 di 3
    • Insert the seal punch into the tip of the latex tube to pierce a hole.
  5. How to Fill a Gap with Latex Caulk: passo 5, immagine 1 di 3 How to Fill a Gap with Latex Caulk: passo 5, immagine 2 di 3 How to Fill a Gap with Latex Caulk: passo 5, immagine 3 di 3
    • Pull back the handle of the caulk gun.
    • Place the caulk tube inside it.
    • Twist the metal bar until it is completely inside the caulk tube and the curved handle is on top.
  6. How to Fill a Gap with Latex Caulk: passo 6, immagine 1 di 3 How to Fill a Gap with Latex Caulk: passo 6, immagine 2 di 3 How to Fill a Gap with Latex Caulk: passo 6, immagine 3 di 3
    • Add the latex to the areas you see gaps.
    • After finishing each side, slide your finger along the caulk to push the material inside the gaps.
    • Use a wipe to immediately clean the excess from the filled areas.
  7. How to Fill a Gap with Latex Caulk: passo 7, immagine 1 di 1
    • Use latex remover spray to remove any material stuck to your hand.
Linea Traguardo
Ehsan Alagheband
Membro da: 09/16/21
153 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 846
