Salta al contenuto principale
How to Dust a MSI GS70
Cosa ti serve
  1. How to Dust a MSI GS70, How to Dust a MSI GS70: passo 1, immagine 1 di 2 How to Dust a MSI GS70, How to Dust a MSI GS70: passo 1, immagine 2 di 2
    • Remove the nineteen screws from the back plate using a JIS #1 screwdriver.
    • Locate one of the openings on the side and gently pull up to remove the back plate.
  2. How to Dust a MSI GS70: passo 2, immagine 1 di 1
    • Inspect computer fan for dust accumulation. If dusty, move on to the next step.
  3. How to Dust a MSI GS70: passo 3, immagine 1 di 1
    • With the compressed air, blow at an angle and from a distance to displace the dust.
    • You do NOT need to blow for very long. Blowing for a long period can damage the fan.
    • Use vacuum after blowing to clean up any dust left behind.
Conclusione
After blowing out your fans, go in reverse order to put everything back together properly. After this, your MSI GS70 is ready to go.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,763
