Salta al contenuto principale
How to Dry Wet Canon PowerShot SD850 IS Camera Components
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Battery: passo 1, immagine 1 di 1
    • Identify the battery port on the underside of the camera.
  2. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 2, immagine 1 di 2 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 2, immagine 2 di 2
    • Using your thumb, slide the port to the right and release.
  3. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 3, immagine 1 di 1
    • Remove the battery.
  4. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, immagine 1 di 3 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, immagine 2 di 3 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: passo 4, immagine 3 di 3
    • To avoid severe electric shock do not remove or tamper with internal camera flash components. An electrical capacitor is attached to the flash that can discharge if contact is made.
    • Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
    • Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
    • Remove the front face by gently peeling the housing away from the camera.
  5. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, immagine 1 di 3 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, immagine 2 di 3 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 5, immagine 3 di 3
    • Remove the back face by using a spudger to lift the tab highlighted in yellow
    • Pivot the back face clockwise as seen in the second photo.
  6. How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 6, immagine 1 di 2 How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 6, immagine 2 di 2
    • Remove the A/V port cover [no tools are necessary]
  7. How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 7, immagine 1 di 2 How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: passo 7, immagine 2 di 2
    • Use compressed air to dry off camera's internal components.
    • Use caution when performing this step. Compressed air could possibly damage components if sprayed directly at connections or other sensitive areas.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,481
