Salta al contenuto principale
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: passo 1, immagine 1 di 1
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: passo 2, immagine 1 di 1
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: passo 3, immagine 1 di 2 How to Clear a blocked, or clogged sink: passo 3, immagine 2 di 2
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: passo 4, immagine 1 di 1
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: passo 5, immagine 1 di 1
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: passo 6, immagine 1 di 1
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: passo 7, immagine 1 di 1
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
Conclusione
Your sink should now be free of obstructions or clogs in the pipes.
Altre 4 persone hanno completato questa guida.
Pasco Hernando, Team 5-1, Prince Fall 2015 Membro di Pasco Hernando, Team 5-1, Prince Fall 2015
PHSC-PRINCE-F15S5G1
1 Membro
1 Guida realizzata
Un commento
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,324
