Salta al contenuto principale
How to Cleanly Remove Stickers from a Laptop
Cosa ti serve
  1. How to Cleanly Remove Stickers from a Laptop, Remove the battery (Laptops only): passo 1, immagine 1 di 2 How to Cleanly Remove Stickers from a Laptop, Remove the battery (Laptops only): passo 1, immagine 2 di 2
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. How to Cleanly Remove Stickers from a Laptop, Warm up the adhesive: passo 2, immagine 1 di 3 How to Cleanly Remove Stickers from a Laptop, Warm up the adhesive: passo 2, immagine 2 di 3 How to Cleanly Remove Stickers from a Laptop, Warm up the adhesive: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Picks (Set of 6)
    • 30-60 seconds of heat is sufficient.
    • If you are removing a thin or stubborn sticker, a guitar pick may help with these to minimize the post removal mess.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. How to Cleanly Remove Stickers from a Laptop, Clean the remaining glue: passo 3, immagine 1 di 3 How to Cleanly Remove Stickers from a Laptop, Clean the remaining glue: passo 3, immagine 2 di 3 How to Cleanly Remove Stickers from a Laptop, Clean the remaining glue: passo 3, immagine 3 di 3
    • While denatured alcohol works, it may "strip" some rubber coatings and paint. It should only be done as a last resort or on surfaces like aluminum!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Nick
Membro da: 11/10/09
98.614 Reputazione
63 Guide realizzate
Master Techs Membro di Master Techs
Community
329 Membri
1.451 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 247
Tutti i Tempi: 19,001
