Salta al contenuto principale
How to Clean the Rollers on an HP Deskjet 2624
Cosa ti serve
    • Perform an automated self-clean by holding down the power button.
    • While the power button is held, press the button with the large red 'X' three times then press the button with the yellow, blue, and pink rim eight times.
    • Release the power button. A single sheet of paper should be fed through the printer.
    • Wait until the paper is completely through the printer before removing it.
  1. How to Clean the Rollers on an HP Deskjet 2624: passo 2, immagine 1 di 1
    • Once the automated is complete, attempt to print again.
    • If the paper jam persists, the rollers must be manually cleaned.
    • Begin by turning off and unplugging the printer.
  2. How to Clean the Rollers on an HP Deskjet 2624: passo 3, immagine 1 di 2 How to Clean the Rollers on an HP Deskjet 2624: passo 3, immagine 2 di 2
    • To access the rollers, remove all the paper in the feeding tray.
    • Lift the clear plastic flap on the top of the printer and look down the feeding section.
  3. How to Clean the Rollers on an HP Deskjet 2624: passo 4, immagine 1 di 2 How to Clean the Rollers on an HP Deskjet 2624: passo 4, immagine 2 di 2
    • Take a lightly dampened cotton swab and apply it to the grey segments of the rollers.
    • Rotate the rollers to completely clean the grey segments
Conclusione
Wait approximately 10 minutes for the rollers to dry completely.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,248
