Salta al contenuto principale
How to Clean the Fan on a Toshiba TDP-XP2
Cosa ti serve
  1. How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: passo 1, immagine 1 di 2 How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: passo 1, immagine 2 di 2
    • Remove the two screws from the bottom plate as shown.
  2. How to Clean the Fan on a Toshiba TDP-XP2: passo 2, immagine 1 di 1
    • Remove the two screws on the bulb housing.
  3. How to Clean the Fan on a Toshiba TDP-XP2: passo 3, immagine 1 di 1
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
  4. How to Clean the Fan on a Toshiba TDP-XP2: passo 4, immagine 1 di 1
    • Using a can of compressed air, blow on the fan until all dust is gone.
    • Oil can be added in with a dropper on the bearing if needed.
Conclusione
Bryan Underwood
Membro da: 04/02/18
697 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 512
