Salta al contenuto principale
How to Clean the Deck of a Greenworks M060L00
Cosa ti serve
    1. How to Clean the Deck of a Greenworks M060L00, How to Clean the Deck of a Greenworks M060L00: passo 1, immagine 1 di 2 How to Clean the Deck of a Greenworks M060L00, How to Clean the Deck of a Greenworks M060L00: passo 1, immagine 2 di 2
      • Remove battery and safety key.
      • Position the lawnmower on its side. Ensure the working surface is level and firm.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Clean the Deck of a Greenworks M060L00: passo 2, immagine 1 di 1
      • Secure the lawnmower blade with a block of wood.
      • The lawnmower blade will want to rotate counterclockwise. Place the correct end of the blade against the wood block to avoid unnecessary blade rotation.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Clean the Deck of a Greenworks M060L00: passo 3, immagine 1 di 1
      • Remove the bolt holding the lawnmower blade using a 17mm wrench or socket wrench.
      • Wear heavy work gloves if you are worried about working around a sharp lawnmower blade.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Clean the Deck of a Greenworks M060L00: passo 4, immagine 1 di 1
      • Use a plastic scraper to remove grass and debris from the underside of the lawnmower deck.
      • A metal scraper may damage the coating on the lawnmower allowing for rust to form.
      Chiedi a FixBot
      Aggiungi Commento
    5. How to Clean the Deck of a Greenworks M060L00: passo 5, immagine 1 di 1
      • Optional: Use a brass brush to remove finer particles from lawn mower deck.
      • Brass brushes are soft enough to avoid scraping the protective coating. Use of a steel brush is not advised for this reason.
      Chiedi a FixBot
      Aggiungi Commento
    6. How to Clean the Deck of a Greenworks M060L00: passo 6, immagine 1 di 1
      • Replace the blade assembly. Hand tighten the lawnmower blade bolt.
      Chiedi a FixBot
      Aggiungi Commento
    7. How to Clean the Deck of a Greenworks M060L00: passo 7, immagine 1 di 1
      • Ensure the blade is blocked to resist clockwise rotation.
      • Tighten the lawnmower bolt using a 17mm wrench or socket wrench.
      • Do not overtighten the lawnmower blade bolt. Overtightening could cause the bolt to crack.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Regular cleaning of your lawnmower is a simple task that allows the machine to run smoothly while increasing its lifespan. Electric lawnmowers cannot get wet, so using a power washer or hose makes the cleaning process slightly more involved. Despite this, it is still a relatively simple process that will make mowing your lawn a more enjoyable process.
Caleb
Membro da: 03/04/25
145 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 65
Tutti i Tempi: 457
