Salta al contenuto principale
How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar
Cosa ti serve
  1. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 1, immagine 1 di 2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 1, immagine 2 di 2
    • Clear the workspace of any items or clutter that could damage the finish of the guitar.
    • Support the neck of the guitar with a stand or bag.
    • In this case, a neck stand was not available, so a toiletries bag with towels stuffed inside was used to support the neck of the guitar.
    • You are good to go as long as it is stable and supports the guitar's neck well.
  2. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 2, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 2, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 2, immagine 3 di 3
    • Using the string winder, unwind the strings.
    • It is okay to relieve all of the tension on the neck by unwinding all of the strings at once.
  3. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 3, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 3, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 3, immagine 3 di 3
    • Using the string winder, pull up the bridge pins.
    • Remove the old strings.
    • This allows complete access to clean and oil the frets and fretboard.
  4. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 4, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 4, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Use a scouring pad to clean and oil the fretboard, frets, and bridge with the Dunlop Lemon Oil.
    • Let the oil sit and seep into the wood for five minutes.
    • This is done so that the oil is absorbed into the wood of the fretboard and bridge, benefitting the longevity and life of the wood.
    • Once done, wipe off all of the excess oil with a microfiber cloth.
  5. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 5, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 5, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 5, immagine 3 di 3
    • It is important to use clean microfiber cloths for this step.
    • Use the Dunlop cleaner to clean the front, back, sides, and neck of the guitar.
    • Finish up with the Dunlop Carnauba wax to polish the front, back, sides, and neck of the guitar.
  6. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 6, immagine 1 di 2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 6, immagine 2 di 2
    • Insert the new strings into the bridge holes.
    • Pop the bridge pins down into place.
    • Make sure to keep tension on the strings as the bridge pins are popped down into place.
  7. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 7, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 7, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 7, immagine 3 di 3
    • Cut the strings to size.
    • For the bass strings, measure one tuner head's length and trim it there.
    • For the treble strings, measure one and a half tuner head's length and trim it there.
    • When inserting the string into the tuning post, the string end should protrude approximately 1/8th of an inch from the tuner hole.
    • The bass side tuning pegs should be turned in a counter-clockwise direction to tune to pitch and the treble side tuning pegs should be turned in a clockwise direction to tune to pitch.
    • Make sure to remember that the wraps around the tuning post must go under the string to properly stay in tune and to avoid creating a kink, which could break the string.
    • Two to three wraps are perfect for the bass strings. The treble strings require approximately six wraps.
  8. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 8, immagine 1 di 1
    • Use a tuner to tune all of the strings to their proper notes.
    • The standard tuning for a six-string guitar is E A D G B E, which reads from the Low E (6th string) to the High E (1st string).
  9. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 9, immagine 1 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 9, immagine 2 di 3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 9, immagine 3 di 3
    • Stretch out each of the strings to help them intonate and stay in tune faster.
    • You will have to tune the guitar multiple times until the strings stay in tune when stretched.
    • Repeat this step until the guitar stays in tune.
  10. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: passo 10, immagine 1 di 1
    • Enjoy your newly strung, cleaned, and maintained instrument.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,960
