Salta al contenuto principale
How to Clean a Kitchen Aerator
Cosa ti serve
  1. How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: passo 1, immagine 1 di 2 How to Clean a Kitchen Aerator, How to Clean a Kitchen Aerator: passo 1, immagine 2 di 2
    • Shut off valves that are located under the sink and position faucet in the center to drain remaining water.
  2. How to Clean a Kitchen Aerator: passo 2, immagine 1 di 1
    • Avoid dropping small parts down the sink by covering the surface of the holes.
  3. How to Clean a Kitchen Aerator: passo 3, immagine 1 di 1
    • Unscrew and remove aerator with a wrench.
  4. How to Clean a Kitchen Aerator: passo 4, immagine 1 di 1
    • Clean aerator by soaking it in white vinegar overnight in a bowl or cup.
  5. How to Clean a Kitchen Aerator: passo 5, immagine 1 di 1
    • Dry off aerator with a towel.
  6. How to Clean a Kitchen Aerator: passo 6, immagine 1 di 1
    • Use a wrench to screw back on the aerator to the faucet.
  7. How to Clean a Kitchen Aerator: passo 7, immagine 1 di 1
    • Slowly turn back on water valves to check for improves water pressure.
    • Make sure sink is cleared and components of faucet that were removed are sealed tight.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,438
