Salta al contenuto principale
How to Clean a Flat Iron
Cosa ti serve
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: passo 1, immagine 1 di 1
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: passo 2, immagine 1 di 2 How to Clean a Flat Iron: passo 2, immagine 2 di 2
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: passo 3, immagine 1 di 2 How to Clean a Flat Iron: passo 3, immagine 2 di 2
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: passo 5, immagine 1 di 2 How to Clean a Flat Iron: passo 5, immagine 2 di 2
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: passo 6, immagine 1 di 2 How to Clean a Flat Iron: passo 6, immagine 2 di 2
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: passo 7, immagine 1 di 1
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: passo 8, immagine 1 di 1
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: passo 9, immagine 1 di 1
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
Conclusione
Congratulations your flat iron is buildup free!
Altre 3 persone hanno completato questa guida.
Jacquelin
Membro da: 02/23/15
283 Reputazione
1 Guida realizzata
Cal Poly, Team 12-2, Green Winter 2015 Membro di Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 5,736
