Salta al contenuto principale
How to Clean a Filter on a MAYTAG Laundry Machine
Cosa ti serve
  1. How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, immagine 1 di 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, immagine 2 di 3 How to Clean a Filter on a MAYTAG Laundry Machine, How to Clean a Filter on a MAYTAG Laundry Machine: passo 1, immagine 3 di 3
    • Remove the screws (3) underneath the washing machine using the socket wrench, the extension rod, and the converter.
  2. How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, immagine 1 di 3 How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, immagine 2 di 3 How to Clean a Filter on a MAYTAG Laundry Machine: passo 2, immagine 3 di 3
    • Put a tray/rags underneath the washing machine in case water leaks out.
    • Remove the bottom lid of the washing machine.
  3. How to Clean a Filter on a MAYTAG Laundry Machine: passo 3, immagine 1 di 1
    • Turn the filter counterclockwise until you can pull out the filter.
  4. How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, immagine 1 di 3 How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, immagine 2 di 3 How to Clean a Filter on a MAYTAG Laundry Machine: passo 4, immagine 3 di 3
    • Scrub/wash the filter of debris.
  5. How to Clean a Filter on a MAYTAG Laundry Machine: passo 5, immagine 1 di 1
    • Screw the filter clockwise back into place.
Linea Traguardo
Kaelyn Taing
Membro da: 10/26/22
121 Reputazione
1 Guida realizzata
Un commento
A tricky part of this maintenance task is removing and replacing the front cover behind which the filter resides. This guide is inadequate for that part of the job.
Carlo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 98
Ultimi 30 Giorni: 456
Tutti i Tempi: 7,201
