Introduzione
In this guide, I am going to show you how to clean up solder pads on a logic board. I'll be working on a Chinese A13 Allwinner tablet. I'm cleaning the solder pads for the battery, so I can solder a new battery onto the logic board.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:FixHub | Power Series Smart Soldering Iron$79.95
Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
For more soldering guides and tips, check out this page.
Altre 91 persone hanno completato questa guida.
