Salta al contenuto principale
How to Clean Nintendo Entertainment System Cartridges
Cosa ti serve
  1. How to Clean Nintendo Entertainment System Cartridges, Take Apart the Cartridge: passo 1, immagine 1 di 1
    • Remove the three screws on the bottom of the cartridge. While most of the time the screws are security screws, sometimes there are Phillips/Flathead screws.
  2. How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: passo 2, immagine 1 di 2 How to Clean Nintendo Entertainment System Cartridges, Mix the Abrasive Paste: passo 2, immagine 2 di 2
    • Simply put about 2 tablespoons of baking soda on the cartridge contacts. Then put enough water on the baking soda until it is the consistency of a thick paste.
  3. How to Clean Nintendo Entertainment System Cartridges, Scrub the Contacts: passo 3, immagine 1 di 1
    • Take something like a toothbrush or the scraping part of a sponge and scrub the cartridge contacts.
    • After scrubbing for about 4-5 minutes, rinse the cartridge board off in the sink. Let it dry for about 4 hours after pouring alcohol under the chips.
Conclusione
And with that your cartridge should be working properly!
Altre 3 persone hanno completato questa guida.
[deleted]
Membro da: 06/12/22
569 Reputazione
2 Guide realizzate
4Commenti sulla guida
Is this a joke?
Mizuho Chan - Replica
Why would it be a joke? Because it's a simple procedure that everybody should know? Or do you have a better way?
Randall Mattoon -
In my opinion, a less abrasive metal polish would probably be better to start with.
Jeff Griffith - Replica
Whatever happened to the tried and true method of blowing on the cartridge? It worked as a kid (back when we didn’t know that our breath had water vapor and we were actually destroying our cartridges)!
mwbarnhart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 103
Tutti i Tempi: 5,002
