Salta al contenuto principale
How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: passo 1, immagine 1 di 1
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: passo 2, immagine 1 di 1
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: passo 3, immagine 1 di 1
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: passo 4, immagine 1 di 1
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  5. How to Check Your iPhone's Battery Health: passo 5, immagine 1 di 3 How to Check Your iPhone's Battery Health: passo 5, immagine 2 di 3 How to Check Your iPhone's Battery Health: passo 5, immagine 3 di 3
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
Conclusione
That's all folks!
Altre 26 persone hanno completato questa guida.
Josh M
Membro da: 11/24/14
877 Reputazione
1 Guida realizzata
iTech West Palm Beach Membro di iTech West Palm Beach
Business
5 Membri
7 Guide realizzate
4 Commenti
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - Replica
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - Replica
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M -
mine iphone 6 cannot watch battery health
gfght - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 151
Tutti i Tempi: 10,460
