Salta al contenuto principale
How to Check Battery Health Using CROSH
    • From your Desktop use the key combination Ctrl + Alt + T
    • In the CROSH terminal type in battery_test [< test length >]
    • The test length is measured in seconds. if no number is put in, then the test length will default to 300 seconds.
    • You can also use the command battery_firmware info to get additional information about your battery's including serial number, chemistry, and design capacity.
Conclusione
This command is extremely useful for determining if your Chromebook's battery is operating at peak performance, of if there is an issue with the battery.
Altre 4 persone hanno completato questa guida.
Jacob Mehnert
Membro da: 10/18/21
44.184 Reputazione
51 Guide realizzate
iFanatics Membro di iFanatics
Community
63 Membri
218 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 89
Tutti i Tempi: 5,157
