Introduzione
Changing the high-pressure valve on a Stand-Up Paddleboard (SUP) is a straightforward process that can help maintain the board’s performance and longevity. Whether you’re dealing with a faulty valve or simply performing routine maintenance, following these instructions will ensure your SUP remains in good condition. Let's get started!
Cosa ti serve
Locate the valve that needs to be replaced (red arrow).
Prepare the area with all the tools needed for the repair.
Start by pressing the center of the valve with your thumb to open it.
Apply pressure with both hands to deflate the SUP and let the air out.
Use the valve tool by placing it on top of the valve and rotating until the old valve comes out.
Insert the new part by placing it on top of the valve hole and rotating it.
Use the valve tool to fix the valve in its new position and making it as tight as possible.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
