Salta al contenuto principale
How to Change an Indoor Doorknob Handle
Cosa ti serve
  1. How to Change an Indoor Doorknob Handle, How to Change an Indoor Doorknob Handle: passo 1, immagine 1 di 1
    • Parts: (in order from left to right)
    • Short Screws
    • Latch mechanism with latch face
    • Long screws
    • Door knob with peg and screw holes (inside of the room)
    • Door knob with screw holes (outside of the room)
  2. How to Change an Indoor Doorknob Handle: passo 2, immagine 1 di 1
    • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
  3. How to Change an Indoor Doorknob Handle: passo 3, immagine 1 di 1
    • Unscrew both long screws.
  4. How to Change an Indoor Doorknob Handle: passo 4, immagine 1 di 1
    • Remove the door knob on both sides of the door.
  5. How to Change an Indoor Doorknob Handle: passo 5, immagine 1 di 1
    • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
  6. How to Change an Indoor Doorknob Handle: passo 6, immagine 1 di 1
    • Unscrew the two short screws on the latch face plate.
  7. How to Change an Indoor Doorknob Handle: passo 7, immagine 1 di 1
    • Remove the latch face plate and latch mechanism.
  8. How to Change an Indoor Doorknob Handle: passo 8, immagine 1 di 1
    • Push the new latch mechanism with latch face plate into the door.
    • The slanted side of the latch mechanism will be facing the direction that the door closes.
  9. How to Change an Indoor Doorknob Handle: passo 9, immagine 1 di 1
    • Screw in both short screws of the latch face plate.
  10. How to Change an Indoor Doorknob Handle: passo 10, immagine 1 di 1
    • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  11. How to Change an Indoor Doorknob Handle: passo 11, immagine 1 di 1
    • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
  12. How to Change an Indoor Doorknob Handle: passo 12, immagine 1 di 1
    • Screw in both long screws on both sides of the door knob.
  13. How to Change an Indoor Doorknob Handle: passo 13, immagine 1 di 1
    • Turn the door knob to test your work.
Conclusione
To put the old door knob back on or to change to a different door knob repeat steps from the beginning.
Altre 7 persone hanno completato questa guida.
Mallory
Membro da: 02/19/15
235 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 56
Tutti i Tempi: 10,259
