Salta al contenuto principale
How to Change Mortise Lock and its Cylinder
Cosa ti serve
  1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, immagine 1 di 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, immagine 2 di 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: passo 1, immagine 3 di 3
    • Determine the position of the screws on both door handles and the front plate.
  2. How to Change Mortise Lock and its Cylinder: passo 2, immagine 1 di 2 How to Change Mortise Lock and its Cylinder: passo 2, immagine 2 di 2
    • Use a flathead screwdriver to remove the eight 6 mm screws on both handles.
  3. How to Change Mortise Lock and its Cylinder: passo 3, immagine 1 di 3 How to Change Mortise Lock and its Cylinder: passo 3, immagine 2 di 3 How to Change Mortise Lock and its Cylinder: passo 3, immagine 3 di 3
    • Pull out the door handles on both sides of the door.
  4. How to Change Mortise Lock and its Cylinder: passo 4, immagine 1 di 3 How to Change Mortise Lock and its Cylinder: passo 4, immagine 2 di 3 How to Change Mortise Lock and its Cylinder: passo 4, immagine 3 di 3
    • Pull out the spindle (the rectangular piece of metal) from the door.
  5. How to Change Mortise Lock and its Cylinder: passo 5, immagine 1 di 3 How to Change Mortise Lock and its Cylinder: passo 5, immagine 2 di 3 How to Change Mortise Lock and its Cylinder: passo 5, immagine 3 di 3
    • Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
    • Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
  6. How to Change Mortise Lock and its Cylinder: passo 6, immagine 1 di 2 How to Change Mortise Lock and its Cylinder: passo 6, immagine 2 di 2
    • Pull the lock cylinder out to either side of the door.
  7. How to Change Mortise Lock and its Cylinder: passo 7, immagine 1 di 3 How to Change Mortise Lock and its Cylinder: passo 7, immagine 2 di 3 How to Change Mortise Lock and its Cylinder: passo 7, immagine 3 di 3
    • Grasp the mortise lock on either side and pull it out from the edge of the door.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 59
Tutti i Tempi: 3,420
