Salta al contenuto principale
How to Change Broken Buttons on your Lexus Key Fob
    1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: passo 1, immagine 1 di 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: passo 1, immagine 2 di 2
      • Place the key fob with the removable metal key facing towards you.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 3 di 3
      • With the button side facing you, pull the metal latch down towards you to pull out the key.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 3 di 3
      • With the exposed corner facing you, place the metal key into the slot.
      • Turn the key sideways to open the key fob.
      • You may feel like you're breaking the key fob, but be firm while twisting.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Change Broken Buttons on your Lexus Key Fob: passo 4, immagine 1 di 2 How to Change Broken Buttons on your Lexus Key Fob: passo 4, immagine 2 di 2
      • Remove the motherboard and battery to access the buttons.
      Chiedi a FixBot
      Aggiungi Commento
    5. How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 3 di 3
      • Rotate the front plate, the broken buttons should fall out with ease.
      • Replace the broken buttons as necessary.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
Altre 7 persone hanno completato questa guida.
Michael Tan
Membro da: 01/08/15
590 Reputazione
3 guide realizzate
Cal Poly, Team 30-3, Green Spring 2015 Membro di Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Membri
14 guide realizzate
1Commento della guida
useless guide
Davide - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 62
Tutti i Tempi: 7,479
