Salta al contenuto principale
How to Buff an Apple Watch
Cosa ti serve
  1. How to Buff an Apple Watch, How to Buff an Apple Watch: passo 1, immagine 1 di 2 How to Buff an Apple Watch, How to Buff an Apple Watch: passo 1, immagine 2 di 2
    • Flip the watch over so it is face down.
  2. How to Buff an Apple Watch: passo 2, immagine 1 di 3 How to Buff an Apple Watch: passo 2, immagine 2 di 3 How to Buff an Apple Watch: passo 2, immagine 3 di 3
    • Remove the straps by pressing the button adjacent to each side and sliding the band right out.
  3. How to Buff an Apple Watch: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Clean the watch with a microfiber cloth.
    • Make sure all smudges are removed at this point.
  4. How to Buff an Apple Watch: passo 4, immagine 1 di 3 How to Buff an Apple Watch: passo 4, immagine 2 di 3 How to Buff an Apple Watch: passo 4, immagine 3 di 3
    • Put on Gloves. Using a polishing cloth, which is already soaked with polishing cream, rub one side of the watch back and forth.
    • Repeat on each side of the watch.
    • When using the polishing cloth, do NOT go directly over the microphone or the speaker.
    • If the polishing cloth begins to turn black while you are wiping, do not be alarmed. The blackness is just layers of dirt coming off the watch.
  5. How to Buff an Apple Watch: passo 5, immagine 1 di 1
    • Grab your microfiber cloth and go over the same area that you previously wiped until the residue is gone and you have restored the side to it’s previous mirror finish.
  6. How to Buff an Apple Watch: passo 6, immagine 1 di 2 How to Buff an Apple Watch: passo 6, immagine 2 di 2
    • After the watch has been restored, slide the straps back into place (you will feel a click).
Conclusione
Congratulations! You have finished buffing your Apple watch!
Altre 2 persone hanno completato questa guida.
Goose
Membro da: 07/31/17
170 Reputazione
1 Guida realizzata
1Commento della guida
Does this work for the gold or graphite cases as well?
David Fernandes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 52
Tutti i Tempi: 8,917
