Salta al contenuto principale
How to Blanket Stitch
Cosa ti serve
  1. How to Blanket Stitch, How to Blanket Stitch: passo 1, immagine 1 di 2 How to Blanket Stitch, How to Blanket Stitch: passo 1, immagine 2 di 2
    • Pick a thread of your choice: fabric or sewing thread.
    • Cut a relatively long piece.
  2. How to Blanket Stitch: passo 2, immagine 1 di 3 How to Blanket Stitch: passo 2, immagine 2 di 3 How to Blanket Stitch: passo 2, immagine 3 di 3
    • Pull one end of thread through the eye of the needle.
    • Make the two tail ends meet.
    • Tie a knot.
  3. How to Blanket Stitch: passo 3, immagine 1 di 1
    • Lay your blanket (or piece of fabric) in front of you and pick your stitching direction.
    • We are stitching left to right!
  4. How to Blanket Stitch: passo 4, immagine 1 di 2 How to Blanket Stitch: passo 4, immagine 2 di 2
    • Measure about half an inch from the edge of your blanket and mark it.
    • Send your needle through the blanket from the back from the marked point.
    • When pushing your needle through the blanket make sure your fingers are not near the needle.
  5. How to Blanket Stitch: passo 5, immagine 1 di 1
    • Bring the thread around the fabric and push the needle through the very first stich creating a loop.
    • Do not pull the thread all the way though, as you will need the loop for the next step.
  6. How to Blanket Stitch: passo 6, immagine 1 di 2 How to Blanket Stitch: passo 6, immagine 2 di 2
    • Push the needle through the loop and pull.
  7. How to Blanket Stitch: passo 7, immagine 1 di 3 How to Blanket Stitch: passo 7, immagine 2 di 3 How to Blanket Stitch: passo 7, immagine 3 di 3
    • Move about half an inch from the first stitch.
    • Send the needle through the blanket from the back creating a loop.
  8. How to Blanket Stitch: passo 8, immagine 1 di 2 How to Blanket Stitch: passo 8, immagine 2 di 2
    • Push the needle through the loop and pull and repeat!
  9. How to Blanket Stitch: passo 9, immagine 1 di 2 How to Blanket Stitch: passo 9, immagine 2 di 2
    • Repeat the process through the edge of your blanket till you reach the end.
Conclusione
To reverse these steps, use a pair of scissors to cut the thread.
Altre 3 persone hanno completato questa guida.
katya
Membro da: 05/10/21
259 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 105
Tutti i Tempi: 2,219
