Introduzione
One of the less intuitive but still very important parts of guitar maintenance is adjusting the truss rod. While this shouldn’t be used to adjust the guitar’s action, it can help to avoid fret buzz and keep the action consistent across the neck. While if you’re careful this process is safe, you do need to be aware that you can accidentally strip the threads of the truss rod or even snap the neck of the guitar if handled improperly. You will also need to let the guitar rest overnight, so we would recommend doing this after daily practice. The truss rod should be adjusted roughly twice a year if your guitar sees excessive play.
Adjustments to the truss rod can make the guitar strings looser or tighter while maintaining the same tuning, so you can make them easier to bend by loosening it. However, if your strings have become a bit too loose to the point that they are producing fret buzz under normal use, you’ll want to tighten the truss rod to eliminate the buzz. Regardless of your needs, this guide will instruct you through the process of adjusting the truss rod on your electric guitar, using a 2011 Epiphone Les Paul Special II guitar as a model.
Cosa ti serve
Remove the three 12.7 mm screws from the truss rod cap on the head-stock with a Phillips #0 screwdriver.
While playing the guitar is very much possible after adjusting the truss rod, it can easily change during a longer practice session. Playing on an over tightened truss rod can potentially damage the neck, so be sure that the adjustments you made were sound before playing excessively.
Altre 2 persone hanno completato questa guida.
2 Commenti
In the intro you talk about tightening the truss rod to relieve fret buzz. Tightening the truss rod will produce more back-bow and result in more fret buzz. Also, how can you have looser strings and still have the same "tuning"? Strings need a certain tension for a certain length to produce the pitch you are after.
Notes on Fret 18 & 19 on high E sound the same.(Just on high E, ever other notes sounds good). Help 🙏
