Salta al contenuto principale
How to Adjust a Buttonhole Size
Cosa ti serve
  1. How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: passo 1, immagine 1 di 3 How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: passo 1, immagine 2 di 3 How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: passo 1, immagine 3 di 3
    • Steps 1-3 demonstrate how to shorten a buttonhole when the button will not stay buttoned or needs to be replaced with a smaller button.
    • Using the ruler, measure the button you intend to use. Add 1/8” to this measurement for ease of buttoning.
  2. How to Adjust a Buttonhole Size: passo 2, immagine 1 di 1
    • Measure down from the top of the existing buttonhole to the length of your Step 1 measurement.
    • Make a small sewing chalk mark or insert a straight pin to mark how long your adjusted buttonhole should be.
  3. How to Adjust a Buttonhole Size: passo 3, immagine 1 di 3 How to Adjust a Buttonhole Size: passo 3, immagine 2 di 3 How to Adjust a Buttonhole Size: passo 3, immagine 3 di 3
    • Use either a sewing machine or needle and thread for this step.
    • Match the stitch width of the existing bar tack, and sew a new bar tack at the location of your chalk mark.
    • A bar tack is several long, narrowly spaced stitches that form the top of a T between shorter perpendicular stitches.
    • Check to make sure your button fits your adjusted buttonhole well.
  4. How to Adjust a Buttonhole Size: passo 4, immagine 1 di 2 How to Adjust a Buttonhole Size: passo 4, immagine 2 di 2
    • Steps 4-8 demonstrate how to lengthen a buttonhole if it is too tight for your button or if you want to sew on larger buttons.
  5. How to Adjust a Buttonhole Size: passo 5, immagine 1 di 3 How to Adjust a Buttonhole Size: passo 5, immagine 2 di 3 How to Adjust a Buttonhole Size: passo 5, immagine 3 di 3
    • With the ruler, measure down from the top of the existing buttonhole to the length of your Step 4 measurement.
    • Make a small sewing chalk mark or insert a straight pin on the fabric at this place.
  6. How to Adjust a Buttonhole Size: passo 6, immagine 1 di 2 How to Adjust a Buttonhole Size: passo 6, immagine 2 di 2
    • Starting on the right of the existing buttonhole, stitch to your chalk mark or pin, matching the width of the original stitching.
    • Stitch a new bar tack.
    • Stitch back on your left to just past the original bar tack.
    • Tie off or backstitch your thread.
  7. How to Adjust a Buttonhole Size: passo 7, immagine 1 di 1
    • Using the point of your scissors, cut through the original bar tack and between your new side stitching until you have reached the new bar tack.
    • Do not cut through your new bar tack.
  8. How to Adjust a Buttonhole Size: passo 8, immagine 1 di 2 How to Adjust a Buttonhole Size: passo 8, immagine 2 di 2
    • If using the existing button, you may have to cut it off and move it slightly to be centered in the larger buttonhole and resew it on.
    • Very near the place where your button was originally sewn on, center your button in your adjusted buttonhole. Using chalk or a pin, mark this location.
    • Sew your button on.
    • Check to make sure it fits through your adjusted buttonhole well.
Conclusione
A sewing machine with a buttonhole presser foot is ideal, but this project can be completed with needle and thread.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 192
Tutti i Tempi: 4,838
