Salta al contenuto principale
How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
Cosa ti serve
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 1, immagine 1 di 1
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 2, immagine 1 di 1
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 3, immagine 1 di 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 3, immagine 2 di 2
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 4, immagine 1 di 1
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 5, immagine 1 di 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 5, immagine 2 di 2
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 6, immagine 1 di 1
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, immagine 1 di 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, immagine 2 di 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: passo 7, immagine 3 di 3
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Linea Traguardo
Altre 2 persone hanno completato questa guida.
2 Commenti
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Replica
I need a replacement t25 bolt and square ribbed nut that is shown in step 4. Any help would be stellar.
gr8fuljqr - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 84
Tutti i Tempi: 5,581
