Introduzione
This simple guide is intended to help with adjusting skirt length using a sewing machine. If a purchased skirt feels too short to wear then the steps outlined in this guide will help in adjusting the skirt to your desired length. The material that will be added to lengthen the skirt should be a thin material to ensure that the fall of the material looks more natural.
Cosa ti serve
Try on your skirt and measure to your desired length.
Mark the preferred length with chalk.
Next, measure the width of the skirt.
Lay out the fabric.
Use the sewing tape to measure the required width of the skirt which would be the width of the skirt x2.
Use the sewing tape to measure the required length which would be the length of the skirt plus 2 inches.
To ensure a straight line is cut, make chalk markings on the left side, the middle, and the right side. Use chalk and a ruler to make a connected line.
Use sewing scissors to cut the material in line with the chalk marks.
There will be two threads hanging from the material. Pull the bottom thread (bobbin thread) to make the gathers. Make sure to pull the thread until the length of the material fits the width of the skirt.
Next, continue using straight stitch but adjust stitch length and width to the normal range.
Attach the material to the skirt.
