Salta al contenuto principale
How to Adjust Cantilever Bicycle Brakes
Cosa ti serve
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, immagine 1 di 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, immagine 2 di 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: passo 1, immagine 3 di 3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: passo 2, immagine 1 di 2 How to Adjust Cantilever Bicycle Brakes: passo 2, immagine 2 di 2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: passo 3, immagine 1 di 3 How to Adjust Cantilever Bicycle Brakes: passo 3, immagine 2 di 3 How to Adjust Cantilever Bicycle Brakes: passo 3, immagine 3 di 3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: passo 4, immagine 1 di 1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: passo 5, immagine 1 di 2 How to Adjust Cantilever Bicycle Brakes: passo 5, immagine 2 di 2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: passo 6, immagine 1 di 2 How to Adjust Cantilever Bicycle Brakes: passo 6, immagine 2 di 2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: passo 7, immagine 1 di 2 How to Adjust Cantilever Bicycle Brakes: passo 7, immagine 2 di 2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: passo 8, immagine 1 di 1
    • Flip the bike back onto its wheels.
Conclusione
Go ride your bike!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 955
