Introduzione
A hole in a knit garment can easily be closed with a needle and thread. All you need is some thread in a matching color so that the repair will be as inconspicuous as possible when you’re finished.
Cosa ti serve
Cut a length of thread about 40 cm long.
Turn the sweater inside out. Insert the needle through the garment at your starting point at the top of the hole. Pull the thread through until only about 5 cm of thread is overlapping. Before inserting the thread on the other side of the hole, pick up any open stitches so that no other stitches come loose.
Done! You made it.
Done! You made it.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
