Salta al contenuto principale
How do I replace the wheels on my Tobago trolley?
Cosa ti serve
  1. How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, immagine 1 di 3 How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, immagine 2 di 3 How do I replace the wheels on my Tobago trolley?, Wheels: passo 1, immagine 3 di 3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: passo 2, immagine 1 di 2 How do I replace the wheels on my Tobago trolley?: passo 2, immagine 2 di 2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: passo 6, immagine 1 di 3 How do I replace the wheels on my Tobago trolley?: passo 6, immagine 2 di 3 How do I replace the wheels on my Tobago trolley?: passo 6, immagine 3 di 3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
Conclusione
Follow the instructions in reverse order to finish the repair.
Vaudesport Membro di Vaudesport
Community
3 Membri
96 Guide realizzate
3 Commenti
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - Replica
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 89
Tutti i Tempi: 4,656
