Salta al contenuto principale
How do I replace a broken buckle on my backpack?
Cosa ti serve
  1. How do I replace a broken buckle on my backpack?, Buckle on backpack: passo 1, immagine 1 di 1
    • In order to determine the correct buckle size, measure the webbing. The webbing illustrated here is 15 mm, so you would need a 15 mm buckle.
  2. How do I replace a broken buckle on my backpack?: passo 2, immagine 1 di 3 How do I replace a broken buckle on my backpack?: passo 2, immagine 2 di 3 How do I replace a broken buckle on my backpack?: passo 2, immagine 3 di 3
    • Remove the broken buckle from the webbing by first pulling the webbing through the locking strap and then unthreading it from the buckle.
    • Use a screwdriver or tweezers to help pull the webbing through, if necessary.
Conclusione
Follow the instructions in reverse order to finish your repair.
Altre 6 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Vaudesport Membro di Vaudesport
Community
3 Membri
97 Guide realizzate
1Commento della guida
Used to use Ortlieb panniers and I have recently changes to Vaude Aqua Back Plus for some incremental additional volume and also the external pocket. I could see that it is easy to replace the male end of the buckle but I guess it could almost be the end of the bag if the female end is broken?
…or maybe you could show us as well how to fix that too, so that we could have some comfort other simply praying that this would not happen!
tahiruysal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 53
Tutti i Tempi: 20,140
