Salta al contenuto principale
How do I patch a garment?
Cosa ti serve
    • Using a piece of tailor’s chalk, outline the size of the patch you’ll need to fully cover the area.
    • In order to ensure that the patch looks good and fits the garment, take note of any seams or design elements you can use to design your patch.
  1. How do I patch a garment?: passo 2, immagine 1 di 1
    • Transfer the size and shape of the patch to an appropriate piece of fabric for the patch.
    • Add 1 cm for a seam allowance along the entire patch.
  2. How do I patch a garment?: passo 3, immagine 1 di 1
    • Cut along the outer line of the patch.
  3. How do I patch a garment?: passo 4, immagine 1 di 1
    • Fold over the seam allowance on the patch and iron it down – this will help with sewing the patch on.
    • Lay the patch on the marked line and top stitch it to the fabric close to the edge of the patch.
    • You can use pins to attach the patch to the jacket so it won’t slide around while you’re sewing it on.
    • Use a top stitch to sew around the patch, locking off the first and last stitches by stitching back and forth a few times.
    • Cut away the torn area inside the jacket along the new seam.
Conclusione
Done! You made it.
Un ringraziamento speciale a questi traduttori:
de en
100%
VAUDE Reparaturteam ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Vaudesport Membro di Vaudesport
Community
3 Membri
97 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,828
