Introduzione
Sometimes, the LCD screen on Sony Handycam camcorders, can start wiggling. Essentially, what happens is that the hinge gets unscrewed from the rest of the camera, causing the screen to wiggle and not feel "sturdy".
Cosa ti serve
Unscrew the 2 Phillips #00 screws on the right side of the camera.
Unscrew the 4 Phillips #00 screws form the bottom of the camera.
Remove the battery compartment cover by pulling it while "wiggling" it. It works like a hook.
Unscrew the 2 Phillips #00 screws from the left side.
Unscrew the Phillips #00 screw from the small SD and HDMI compartment on the left side.
Using the opening tool, remove the small panel at the back of the camera.
Carefully use the opening tool or guitar picks to remove the entire right panel from the camera.
Pry the tiny panel off of the left side of the lens, between the lens and the screen hinge, revealing the hinge.
Remove the plastic lens cover, and then remove the inside black "ring" that also contains the lens protector.
Remove the last ring from around the lens, very carefully as the microphone is on it, which is connected with a ribbon cable to the camera.
Then, use a pair of tweezers to carefully disconnect the ribbon cable from the board.
Unscrew the Phillips #00 screw from the left side of the lens, next to the hinge.
Unscrew the 3 Phillips #00 screws from around the lens of the camera.
Then, remove the lens using your tweezers.
Tilt the camera to the side of the screen.
Pull apart the 2 sides of the camera to make some space.
Using your Phillips #00 screwdriver, carefully screw tightly the 2 screws that hold the hinge on the camera.
