Salta al contenuto principale
How To Start Remote Viewfinder on Samsung WB150F
Cosa ti serve
  1. How To Start Remote Viewfinder on Samsung WB150F, Power on the device: passo 1, immagine 1 di 2 How To Start Remote Viewfinder on Samsung WB150F, Power on the device: passo 1, immagine 2 di 2
    • Turn on the device by pressing the button thats labeled POWER on the top.
  2. How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: passo 2, immagine 1 di 2 How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: passo 2, immagine 2 di 2
    • Look at the wheel at the top
    • Scroll until the dot is at Wi-Fi
  3. How To Start Remote Viewfinder on Samsung WB150F: passo 3, immagine 1 di 3 How To Start Remote Viewfinder on Samsung WB150F: passo 3, immagine 2 di 3 How To Start Remote Viewfinder on Samsung WB150F: passo 3, immagine 3 di 3
    • Navigate using the Navigation wheel
    • Navigate until the blue glowing square is on Remote Viewfinder
    • Press OK
  4. How To Start Remote Viewfinder on Samsung WB150F, Setting Up: passo 4, immagine 1 di 1
    • If everything done correctly, You will be on this screen, Time to install the viewfinder app.
  5. How To Start Remote Viewfinder on Samsung WB150F, Finding the app: passo 5, immagine 1 di 1
    • Search up Remote ViewFinder on App Store/Play Store
  6. How To Start Remote Viewfinder on Samsung WB150F, Downloading the app: passo 6, immagine 1 di 1
    • When you found the app, Press the download button
    • If it is a cloud, It means it was installed before, You will not need a password to download it.
    • The App Is pretty outdated, I suggest using iOS 4-10, It wont work on newer iOS
    • An iPhone 5c or an iPad 4 works well.
  7. How To Start Remote Viewfinder on Samsung WB150F, Connecting: passo 7, immagine 1 di 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting: passo 7, immagine 2 di 2
    • Open up settings and go to the Wifi Tab
    • Connect your device to the cameras wifi.
    • The Wifi name should be the same as on the camera.
  8. How To Start Remote Viewfinder on Samsung WB150F, Starting the application: passo 8, immagine 1 di 1
    • Launch Remote Viewfinder on your device
  9. How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: passo 9, immagine 1 di 2 How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: passo 9, immagine 2 di 2
    • Wait until its connected.
    • If you see the screen of your camera Your camera is connected (see step 10 for controls)
  10. How To Start Remote Viewfinder on Samsung WB150F, Controls: passo 10, immagine 1 di 1
    • Flash
    • Timer
    • Photo Size
    • Zoom
    • Shutter Button
    • Camera View
    • Tap the camera view to hide/show the menu.
Conclusione
Close the app, to disconnect your camera from the app
Artem Ivat
Membro da: 02/05/20
3.513 Reputazione
13 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,714
