Salta al contenuto principale
How To Replace Burners on Weber Genesis II Grill
Cosa ti serve
  1. How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, immagine 1 di 3 How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, immagine 2 di 3 How To Replace Burners on Weber Genesis II Grill, Burners: passo 1, immagine 3 di 3
    • This is the Weber Genesis II grill. Before replacement of the burner, we will start by cleaning the grates with a grill brush in order to be clean and safe.
    • Make sure that the grill is completely turned off so there is no chance of accidental burn.
  2. How To Replace Burners on Weber Genesis II Grill: passo 2, immagine 1 di 3 How To Replace Burners on Weber Genesis II Grill: passo 2, immagine 2 di 3 How To Replace Burners on Weber Genesis II Grill: passo 2, immagine 3 di 3
    • Remove the grates using your hands.
    • Grab on each side of the grill grate with your hands and lift straight upwards.
    • Set the removed grate off to the side of the grill.
    • Repeat this procedure for all three of the grates on top of the grill.
  3. How To Replace Burners on Weber Genesis II Grill: passo 3, immagine 1 di 3 How To Replace Burners on Weber Genesis II Grill: passo 3, immagine 2 di 3 How To Replace Burners on Weber Genesis II Grill: passo 3, immagine 3 di 3
    • Remove the heat deflector plates from on top of the burners.
    • Grab each deflector plate and pull straight upwards as with the grates.
    • Place the removed heat deflector plates off to the side of the grill.
    • Repeat this procedure for all heat deflector plates until each burner is exposed.
    • Only half of the heat deflectors plates will have burners underneath them. So do not be alarmed when not all plates have a burner.
  4. How To Replace Burners on Weber Genesis II Grill: passo 4, immagine 1 di 3 How To Replace Burners on Weber Genesis II Grill: passo 4, immagine 2 di 3 How To Replace Burners on Weber Genesis II Grill: passo 4, immagine 3 di 3
    • Remove the burner from its slot in the back of the grill.
    • With both hands, carefully pull the burner upwards and slightly to the left in order to pull it out of its slot.
    • The burners can become stuck and require a little extra force to pull out, but do not pull too hard and hit the top of the grill or yourself.
    • If replacing all burners, repeat this procedure to remove all burners from their slots.
  5. How To Replace Burners on Weber Genesis II Grill: passo 5, immagine 1 di 3 How To Replace Burners on Weber Genesis II Grill: passo 5, immagine 2 di 3 How To Replace Burners on Weber Genesis II Grill: passo 5, immagine 3 di 3
    • Detach the burner from the ignition device.
    • With a small wedge, such as a flat-head screwdriver, unclip the white connector from the burner.
    • With the ignition device removed, you are now all set to replace the burner with a new one.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 81
Ultimi 30 Giorni: 338
Tutti i Tempi: 8,989
