Salta al contenuto principale
How To Repair A Rip In Chiffon Fabric
Cosa ti serve
  1. How To Repair A Rip In Chiffon Fabric, How To Repair A Rip In Chiffon Fabric: passo 1, immagine 1 di 1
    • Locate the rip in the fabric.
  2. How To Repair A Rip In Chiffon Fabric: passo 2, immagine 1 di 1
    • Trim off any fraying at the tear.
    • Fold the fabric in half at the tear and cut off the fraying. This makes it easier to clip the smaller frayed fibers as well.
  3. How To Repair A Rip In Chiffon Fabric: passo 3, immagine 1 di 1
    • Fold the fabric in half at the rip so that the raw edges are right side together.
  4. How To Repair A Rip In Chiffon Fabric: passo 4, immagine 1 di 1
    • Find a permanent fabric adhesive.
  5. How To Repair A Rip In Chiffon Fabric: passo 5, immagine 1 di 1
    • Carefully apply the adhesive to the raw edges.
  6. How To Repair A Rip In Chiffon Fabric: passo 6, immagine 1 di 1
    • Keep the edges together until almost dry.
  7. How To Repair A Rip In Chiffon Fabric: passo 7, immagine 1 di 1
    • Then lay the cloth flat and push the edges together to make sure the ends stay together.
    • Let the adhesive dry completely.
    • At this point, if your tear/repair is large, you can find a patch that can cover the repair and glue it on.
    • Avoid ironing on the patch. This may cause even more damage to fabric as this material is already very delicate.
Conclusione
Now the damage done to your fabric should be contained and the material should be restored to working order. Hope this helped!
Manasa Dintakurthi
Membro da: 10/08/20
145 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 240
Tutti i Tempi: 16,373
