Salta al contenuto principale
How To Remove a Knotted Fishing Reel Line
Cosa ti serve
  1. How To Remove a Knotted Fishing Reel Line, How To Remove a Knotted Fishing Reel Line: passo 1, immagine 1 di 1
    • Find an open area in your home to lay down your fishing pole. Make sure you have space to access the reel comfortably.
  2. How To Remove a Knotted Fishing Reel Line: passo 2, immagine 1 di 1
    • Grab onto the cap of the reel and begin to unscrew it from the base, turning it in a counter-clockwise direction. This will expose the mechanism and line inside.
  3. How To Remove a Knotted Fishing Reel Line: passo 3, immagine 1 di 1
    • Make sure the small peg on the dial is sticking out and holding the line. If this piece is not sticking out, you may have a more complicated problem.
    • This tiny mechanism is what grabs onto the line and spins it back down onto the spool.
  4. How To Remove a Knotted Fishing Reel Line: passo 4, immagine 1 di 1
    • Press in the release button. This will cause the pegs mentioned in the previous step to retract into the bigger mechanism and release any tension in your line.
  5. How To Remove a Knotted Fishing Reel Line: passo 5, immagine 1 di 1
    • Take this time to pull some of the fishing line free from the spool. Make sure it comes loose easily as you pull upwards.
    • If you feel a snag at any time, your thread may have a knot. At this point, it is easier to cut your thread below the knot and re-thread your fishing pole with the rest of the line.
  6. How To Remove a Knotted Fishing Reel Line: passo 6, immagine 1 di 1
    • After inspecting the line, lower the cap back down onto the base and begin turning it clockwise to screw it back on and secure the lid.
  7. How To Remove a Knotted Fishing Reel Line: passo 7, immagine 1 di 1
    • To re-tighten the thread you loosened in the previous steps, simply turn the fishing handle in a clockwise motion.
    • This will cause the small pegs to protrude back out of the inner mechanism and catch the thread, thus pulling and spinning the line back onto the spool.
  8. How To Remove a Knotted Fishing Reel Line: passo 8, immagine 1 di 1
    • Your fishing line should now be free of slack and your reel should be fully reassembled.
    • To test your pole, take it outside to a open area and gently cast it. It should cast in a fluid motion with no blockage in the line.
    • If the line smoothly releases, you have fixed the kink in your line. If your line snags, preventing the pole to cast smoothly, repeat the previous steps to find the blockage.
Conclusione
To reassemble the reel, simply screw the cap back onto the base and reel in any slack line.
Altre 2 persone hanno completato questa guida.
Un commento
Hi Kaitlyn,
It’s really a informative guide for beginners.I would like to know, which Fishing Reel you would recommend for beginners?
Thanks,
Mehedy
topreview geek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 34
Tutti i Tempi: 14,812
